BUG
Executing an SQL query with an ST_Geometry spatial operator fails when using an SQLite database on Linux only. The following errors are returned depending on the ArcGIS Pro version of the ST_Geometry library file.
A ‘Segmentation fault’ error is returned when using the ArcGIS Pro 2.9 and earlier versions of the library:
[testuser@XLinuxTest2265 sqlitetools_33822022]$ sqlite3 st_sqlite.sqlite
SQLite version 3.38.2 2022-03-26 13:51:10
Enter ".help" for instructions
Enter SQL statements terminated with a ";"
sqlite> SELECT load_extension('/tmp/sqlite_stgeom/sqlitetools_33822022/Libraries/ArcGISPro_28_ST_Geometry_SQLite_177726/SQLite/Linux64/libstgeometry_sqlite','SDE_SQL_funcs_init');
sqlite> SELECT ca.OBJECTID, ca.CampingAreaName, count(*) NumCampSites
...> FROM Camping_Areas ca, Campsites cst
...> WHERE ST_Intersects(ca.Shape, cst.Shape)
...> GROUP BY ca.CampingAreaName
...> ORDER BY NumCampSites desc;
Segmentation fault
An 'undefined symbol' error is returned when using the ArcGIS Pro 3.0 version of the library:
sqlite> SELECT load_extension('/tmp/sqlite_stgeom/sqlitetools_33822022/Libraries/ArcGISPro_30_ST_Geometry_SQLite_182273/SQLite/Linux64/libstgeometry_sqlite','SDE_SQL_funcs_init');
Error: /tmp/sqlite_stgeom/sqlitetools_33822022/Libraries/ArcGISPro_30_ST_Geometry_SQLite_182273/SQLite/Linux64/libstgeometry_sqlite.so.so: undefined symbol: SES_sde_date_to_ISO8601_date
Obtain and load an updated libstgeometry_sqlite.so file from My Esri to resolve this.
This library is part of the ArcGIS Pro ST_Geometry SQLite zip file in the Database Support Files selection of the ArcGIS Pro Download Components in My Esri.
Article ID: 000028779
Get help from ArcGIS experts
Start chatting now
