BUG
Some rasters display in the wrong location in 9.2
Some rasters that previously displayed in the correct location in ArcGIS 9.0 & 9.1 now display in the wrong location in 9.2. The raster is offset by a few thousand miles from where it should be located.
Cause
The false easting and/or false northing are not read correctly by 9.2. When viewed in ArcGIS 9.0 & 9.1 the false easting or false northing contained valid values. In 9.2 the false easting and/or false northing is set to zero.
Workaround
Redefine the projection using the Define Projection tool or by editing the spatial reference in ArcCatalog.
    Article ID:000009114
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
