BUG
Sharing is not supported when publishing a locator to ArcGIS Server
An error may be displayed if publishing a locator using ArcGIS for Desktop and sharing the service from the Sharing tab on the Service Editor. Publishing may fail with the error message "Failed to publish service".
Cause
The Sharing tab should not be available when publishing a locator since this function is not supported.
Workaround
Do not select to share services from the Sharing tab on the Service Editor when publishing a locator to ArcGIS Server.
    Article ID:000011852
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
