BUG
Scalebar value is zero for an ArcMap Service
The value of the scalebar acetate layer is zero for an ArcMap Service
Cause
There two known issues that may cause this:
1. **This issue has been resolved in ArcIMS version 4.0.1**
The scalebar value will be zero when the original map is in projected coordinates and the FILTERCOORDSYS in the GET_IMAGE request is in Geographic coordinates.
2.
** This issue has been resolved in ArcGIS 9.0. **
The spatial extent of the map is such that the scalebar is a fraction of the map's unit of measure. For example, if the map's unit of measure is in kilometers and the spatial extent of the map is less than a mile, the scalebar value is zero instead of a fraction of a kilometer.
Workaround
  1. If you are using ArcIMS 4.0, use the same projection to specify FILTERCOORDSYS in the GET_IMAGE request as in the Service.
  2. Scalebars for ArcMap Services (versions 4.0 and 4.0.1) do not support fractional units. To have a usable scalebar use smaller units. For example, use meters instead of kilometers.
Article ID:000005889
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
