BUG
Running ArcGIS Desktop 9.3 and 9.3.1 in a multiuser server environment can result in unexpected behavior
**This issue has been resolved in ArcGIS (Desktop, Engine, Server) 9.3.1 Service Pack 2.**Running ArcGIS Desktop 9.3 or 9.3.1 in a multiuser server environment (for example, Citrix) can result in unexpected behavior. ArcGIS Desktop may inaccurately estimate the amount of available memory on the server which determines the number of concurrent users that can be supported. This may result in the following:▪ "Invalid Geometry" errors when creating or modifying features in an edit session.▪ Empty data frames in layout view and callout text boxes disappearing.
Cause
This is a known issue.
Workaround
Esri has identified the cause and can provide a patch. To request this patch, contact Esri, and a member of the Support Services team will provide assistance.
    Article ID:000010679
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
