BUG
Raster layers that were used in ArcIMS 4.0.1 map services may not appear in ArcIMS 9.0 map services. This occurs when ArcIMS 4.0.1 map configuration files (.axl) are used in an ArcIMS 9.0 map service.
This will occur if data projection is requested and there is no COORDSYS defined for raster layers.
If COORDSYS is not included for an image layer, the following error will be written to the Spatial Server log file: "[ERR0957] Image layer {0} should be projected, but doesn't have a COORDSYS tag. Layer will not be drawn."
See the ArcXML Programmer's Reference Guide for more information about projecting data in ArcIMS
Article ID:000006961
Get help from ArcGIS experts
Download the Esri Support App
