BUG
Printing is limited to the size of the default paper tray
The printer does not produce a printout larger than 8.5" x 11" even if a larger paper size was specified.
Cause
ArcMap's current postscript output engine does not select paper trays. The printer prints to the default paper tray, which is loaded with 8.5" X 11".
Workaround
There are two possible options to print on paper that is larger than 8.5" x 11":
  • The default paper tray (tray1) may be able to be loaded with paper larger than 8.5" x 11". If so, users can print on as large paper as the tray allows.
  • Export the layout to PDF:
    1. Embed the document's fonts on the export options tab.
    2. Use Acrobat Reader to print to the second print tray.
Article ID:000007076
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
