BUG
Pie charts in the ArcMap table of contents as well as legend patches with rounded corners in legends on the ArcMap layout are not drawn correctly.
When a layer is symbolized with pie charts, instead of seeing correct round lines for the outline of the pie chart in the table of contents, there are straight lines that cut across the chart.
When using legend patches with rounded corners, instead of seeing correctly rounded corners, there is a straight line that cuts across the legend patch.
The driver for the Windows graphic adapter is out-of-date.
Article ID:000006795
Get help from ArcGIS experts
Download the Esri Support App
