BUG
Path to tasks.xml is incorrect in tasker.properties file.
The cleanup tasks that are set in tasks.xml are not working.
Cause
The path to the tasks.xml set in tasker.properties is incorrect.
Workaround
  1. Open <ArcIMS install location>\AppServer\Tasker\Tasker.properties in a text editor.
  2. Change the path of 'taskfile' from:
    Code:
    taskFile=<ArcIMS Install Location>\Middleware\Tasker\Tasks.xml
    to
    Code:
    taskFile=<ArcIMS Install Location>/AppServer/Tasker/Tasks.xml
    The direction of the slashes is changed and make sure to fill in the absolute path to <ArcIMS Install Location>, for example: C:/Program Files/ArcGIS/ArcIMS
  3. Save the changes.
  4. Stop and Start ArcIMS Tasker service.
Article ID:000008011
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
