BUG
Output imagery is shifted when using the NITF for ArcGIS extension to convert an image to NITF if source rasters are in certain coordinate systems
After installing the NITF for ArcGIS 9.3.1 extension and using 'NITF Save As' to convert an image to NITF format, or using 'NITF Export Map' to save ArcMap's screen display to NITF format, the output image is shifted if the source image's spatial reference is not one of the following:• GCS_North_American_1927
• GCS_North_American_1983
• GCS_WGS_1984
• UTM projections of the above geographic coordinate systems.If using the NITF for ArcGIS 10.0 extension, rasters with unsupported coordinate systems will be automatically blocked from using the 'NITF Save As' features.
Cause
'NITF Save As' only supports the following coordinate systems for the source image:
• GCS_WGS_1984"
'NITF Export Map' only supports the above coordinate systems for the active data frame in ArcMap.
Workaround
This issue can be resolved by the following workflow:
  1. Use the Project Raster geoprocessing tool to project the source image to one of the supported coordinate systems.
  2. Run the 'NITF Save As' command on the reprojected image.
  3. When using 'NITF Export Map', change data frame's coordinate system to one of the supported coordinate systems.
Article ID:000011073
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
