BUG
Only matching records are preserved when creating a Join through the Layer Properties > Joins and Relates tab
**This issue appears with ArcGIS 9.l, Service Pack 2**If a Join is established in the Layer Properties > Joins and Relates tab, only matching records are preserved. This occurs even if the default of 'Keep All Records' is selected.
Cause
This is a known limitation.
Workaround
Establish the join through the layer context menu, or with the Add Join tool from ArcToolbox.
    Article ID:000008900
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
