BUG
NIM095381: CityEngine transposes the linear units of exported 3D models from feet to meters
When exporting a CityEngine 3D model to a file geodatabase multipatch feature class, linear units of feet are converted to meters, but not the numeric values. That is, a measurement specified as five feet is converted to five meters.
When drawing a model in a CityEngine scene that has a projection with a linear unit of feet, it may be necessary to specify certain sizes for the model (i.e., width, height, etc.) using the Numerical input box, then further extrude it to a 3D object.
For example:
1. Specify a coordinate system for the scene that has linear units in US Feet:
[O-Image]
2. Create a shape in specific size:
[O-Image]
3. Extrude the shape to a 3D model:
[O-Image]
If the model is exported to a file geodatabase multipatch feature class and then measured in ArcMap or ArcScene, the specified units (width, height, etc.) are recorded in meters instead of feet.
Cause
This is a known issue.
Workaround
Resize/rescale the model using the 3D Editor toolbar in ArcScene to make it line up properly with the rest of the data.
The 3D Editor toolbar
    Article ID:000011958
    Software:
    • ArcGIS CityEngine Prev
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
