BUG
Network layer edge arrow symbols are not saved
Changes made to the network layer edge arrow symbols are not saved unless the arrows are checked to be visible.
Cause
Changes to the arrow symbols are only saved if they are checked on to be visible. Otherwise, the symbol will revert back to the default symbol.
Workaround
To save the arrow symbols for the network layer edges, it is necessary to check on the 'Draw arrow on edges', 'Direct', 'Both', and 'None' checkboxes inside the Arrows dialog box to make the arrows visible.
[O-Image] Arrows Dialog Box
    Article ID:000007794
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
