BUG
The service area polygon labels, as seen in the Network Analyst Window, may be incorrect.
For example, if break values of 5, 10 and 30 are used, the labels might appear as:
0 – 5
5 – 10
0 – 15.515
The correct labels should be:
0 – 5
5 – 10
10 – 15.515
Note that the third label incorrectly started at 0 instead of 10.
This problem happens when multiple breaks are used and there is at least one break larger than the largest possible measure that can exist from that particular facility for the network being used. In this case, the breaks went to 30, but the data only supported service areas extending until 15.515.
An alternative workaround is to edit the service area polygon label within the Network Analyst Window after performing the solve.
Article ID:000007796
Get help from ArcGIS experts
Download the Esri Support App
