BUG
Network Analyst: The Network Identify Tool is not enabled
The Network Identify Tool is not enabled when the network dataset is not visible in the active map, even if the network dataset is visible in the magnifier window that currently has focus.
Cause
The Network Identify Tool should be enabled when the network dataset is visible. It is not currently accounting for the fact that the active magnifier window may have crossed the scale suppression boundary that makes it visible and thus identifiable.
Workaround
Currently, there is no workaround for this issue. The network dataset must be visible in the active map for the Network Identify Tool to be enabled.
    Article ID:000007855
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
