BUG
Moving the network dataset's feature classes outside of the feature dataset causes problems with the network dataset
In ArcCatalog, it is possible to drag and drop a feature class that participates in a network dataset outside of the feature dataset. However this can cause problems. For example, it is then not possible to build the network dataset.
Cause
The feature classes of a network dataset are not supposed to be moved outside of their feature dataset.
Workaround
Do not move the network dataset's feature class outside of the feature dataset. If they have already been moved outside of the feature dataset, move them back inside of the feature dataset.
Article ID:000007809
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
