BUG
Models that contain script tools that return output parameters are not being exported to Python properly. As an example, the following steps results in an erroneous python script.1. Create a simple Python script with an output parameter of type double:
Code:
import win32com.client, sys, string
GP = win32com.client.Dispatch("esriGeoprocessing.GPDispatch.1")
GP.SetParameterAsText(0,"100")
Code:
# model_to_script.py
# Created on: Fri Oct 14 2005 11:36:54 AM
# (generated by ArcGIS/ModelBuilder)
# ---------------------------------------------------------------------------# Import system modules
import sys, string, os, win32com.client# Create the Geoprocessor object
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
gp.overwriteoutput = 1# Set the necessary product code
gp.SetProduct("ArcEditor")# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
gp.AddToolbox("C:/Temp/MyToolBox.tbx")
# Local variables...
my_output = "100"
rivers_shp = "C:\\ESRI\\ESRIDATA\\MEXICO\\rivers.shp"
Output_Feature_Class = "C:\\ESRI\\ESRIDATA\\MEXICO\\rivers_SimplifyLine.shp"
Output_Point_Feature_Class = "C:\\ESRI\\ESRIDATA\\MEXICO\\rivers_SimplifyLine_Pnt.shp"# Process: custom_gp_tool...
gp.toolbox = "C:/Temp/MyToolBox.tbx"
gp.custom_gp_tool()# Process: Simplify Line...
gp.SimplifyLine_management(rivers_shp, Output_Feature_Class, "POINT_REMOVE", my_output,
"FLAG_ERRORS", "KEEP_COLLAPSED_POINTS")
Code:
gp.custom_gp_tool()
Code:
my_output = gp.custom_gp_tool()
Article ID:000008624
Get help from ArcGIS experts
Download the Esri Support App
