BUG
Metadata geoprocessing tools do not complete operation with geodatabases accessed from the Database Connections and Database Servers folders
If ArcGIS Desktop is set to use any metadata style other than the default 'Item Description' style, and if a geodatabase item is accessed from either the Database Connections or Database Servers folders, the metadata geoprocessing tools cannot be used to export the item's metadata or perform other tasks. This problem affects the following tools:
• ESRI Metadata Translator
• USGS MP Metadata Translator
• XSLT Transformation
• Export Metadata
• Export Metadata Multiple
• Import Metadata
• Validate Metadata
• Validate Metadata Multiple
• Upgrade Metadata
Cause
The default path created in the Output File parameter for the Esri Metadata Translator, USGS MP Metadata Translator, and XSLT Transformation tools begins with 'Database Connections\'. This is not a valid file path in the computer's operating system; therefore, the output XML files are not created. The metadata model tools use these files as building blocks, and so they are also affected; their intermediate data is not created.
Workaround
Copy the database connection to a local folder and access the geodatabase from that folder instead of from the Database Connections folder. For geodatabases accessed from the Database Servers folder, access the geodatabase from a database connection instead.
  1. Right-click the database connection used to access the geodatabase in the Database Connections folder.
  2. Click Copy.
  3. Select a local folder with write access.
  4. Click Paste.
  5. Double-click the new database connection in the local folder.
  6. Select an item.
  7. Open the Item Description window or click the Description tab in ArcCatalog to view the item's metadata.
  8. Click the Export button.
  9. The default file path created for the output XML file is valid. The file will be created in the folder that contains the database connection.
Article ID:000011279
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
