BUG
Loading a non-XML file using ArcToolbox > Load Settings > From File causes a crash
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2) **When performing the following, the application in use can crash, with or without an error message:1. In the ArcToolbox context menu, select Load Settings > From File.
2. Select 'All Files' in the browser that appears.
3. Select any non-XML file.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
    Article ID:000007314
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
