BUG
Labels and tick marks do not appear along the bottom edge of a measured grid when the data frame property 'clip to shape' is enabled
This issue has been fixed in ArcGIS Desktop 9.3.
Labels and tick marks of a measured grid disappear along the bottom edge when 'clip to shape' is enabled.The example below shows no labels or ticks along the bottom edge: [O-Image] Clip to shape with measured grid
Cause
This known issue occurs when the 'clip to shape' option is enabled on the Data Frame Properties dialog box.
Workaround
Remove the 'clip to shape' option from the Data Frame Properties dialog box.
    Article ID:000009454
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
