BUG
Labeling using "One_label_per_part" is not recognized by multipart point data
When using a label renderer in ArcIMS, the howmanylabels attribute value "one_label_per_part" is not recognized when using multipart point data. Only the first point in a multipoint shape is labeled.
Cause
The ArcIMS spatial server cannot label all parts (points) of a multipart point.
Workaround
A number of potential workarounds exist:
  • Convert the original multipart point data into individual points.
  • Create a multipart line or polygon dataset from the multipart point data; for example, use the extent of individual features, thus creating rectangle polygons. Then use the new multipart line or polygon dataset to label the original layer.
  • Use ArcMap Server.
Article ID:000006978
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
