BUG
Inserted EMF files created in Macromedia Freehand do not print or export to PostScript or ArcPress
An EMF file created in Freehand and inserted as a picture will not print using the 8.x or 9.x PostScript printer engine or the 8.x ArcPress printer engine.
The same file will not export to EPS or any of the 8.x ArcPress formats. Exporting to PDF is not affected.
Cause
This is caused by an incompatibility with EMF files created in Freehand.
Workaround
  • Use the Windows printer engine to print the file.
  • Use other graphics software to generate the EMF file.
Article ID:000003388
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
