BUG
GeoPandas module fails to install from ArcGIS Pro 2.4.3 Python Package Manager
Last Published: May 6, 2024
In ArcGIS Pro version 2.6, Geopandas fails to install into an ArcGIS Pro Python environment.
Cause
This is a known issue that will be resolved in a future release of ArcGIS Pro.
Workaround
Use the following steps to work around the issue:
  1. In ArcGIS Pro, click the Project tab, and then Python to open the Python Package Manager.
  2. Under Project Environment, check that the active environment is not the default environment, arcgispro-py3. If it is, clone the environment before continuing. Learn more about the Python Package Manager.
  3. Once you have confirmed that you are using a cloned Python environment, close ArcGIS Pro and open the command prompt from Windows Start > ArcGIS > Python Command Prompt, then run the following command:
conda install geopandas libtiff=4.0.10
Importing geopandas should be available from a Python interpreter in your ArcGIS Pro environment.
Article ID: 000024177
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
