BUG
Find tool gives incorrect results when a layer contains GlobalID or GUID fields
The Find tool returns incorrect results or no results when a layer contains a GlobalID and/or a GUID field.
Cause
This is a known issue.
Workaround
Turn off the GlobalID/GUID field visibility or remove the GlobalID/GUID field and perform the find again.
  1. Right-click on the layer that contains the GlobalID/GUID field and select Properties.
  2. Click the Fields tab.
  3. Located the GlobalID and/or GUID field(s) and click the check box to uncheck it.
    [O-Image] Turn off the GlobalID/GUID field visibility
Article ID:000010457
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
