BUG
Feature-linked annotation disappears when editing attributes in the source feature class
** This article only applies to ArcGIS 9.2 or earlier. This bug has been resolved at version 9.3. **
When editing the attribute fields of a feature class that participate in a label expression, the feature-linked annotation is disappearing.
To reproduce:
1. Add the ESRI States feature class to ArcMap.
2. In Layer Properties > Labels, type the following expression: [STATE_NAME] + " " + [AREA]. Label the features.
3. Convert the labels to feature-linked annotation.
4. Start editing States.
5. Open the attribute table and change a STATE_NAME value.
6. When the edits are applied, the feature-linked annotation disappears.
Cause
Using the '+' operator in the label expression is causing the text geometry of the feature-linked annotation to be deleted.
Workaround
Use the '&' operator instead of the '+' operator in the label expression.
[STATE_NAME] & " " & [AREA]
    Article ID:000009615
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
