BUG
Error joining tables: Attribute column not found[Microsoft OLE DB Provider for SQL Server: Deferred prepare could not be completed]...
The error can occur when attempting to perform an Advanced Join, in ArcMap 8.3, using the option to "Keep only matching records". The error occurs under the following circumstances:1. The join is between a versioned feature class and an unversioned database table which is loaded into ArcMap through an ArcSDE connection to a SQL Server database. 2. Neither the feature class nor the table are loaded as their respective data owners.The entire error message is:Error joining tables.
Attribute column not found[Microsoft OLE DB Provider for SQL Server: Deferred prepare could not be completed.][<database>.<Feature class owner>.<Feature class name>][STATE_ID=0]
Cause
This is a known issue with ArcSDE 8.3.
Workaround
There are three potential workarounds:
  1. Load either the table or feature class as their respective data owner
  2. Load the table through an OLE DB connection.
  3. Register the table as versioned.
    This issue has been resolved for ArcSDE 9.0.
Article ID:000006704
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
