BUG
Encountering Oracle error ORA-29902: error in executing ODCIIndexStart() routine when creating spatial index with st_geometry
Schemas in Oracle, approximately 24 characters or greater, which attempt to create a spatial index with st_geometry can result in the following Oracle error:
Code:
ORA-06502: PL/SQL: numeric or value error: character string buffer too small
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 125.
The error may also appear in the sde_<service>.log with verbose enabled when creating a spatial index through ArcGIS.For example, a schema named FACILITIES_MANAGEMENT_DEPT (the user name that owns the data) encounters the above error messages when creating an st_geometry spatial index.The index is created, but the issue causes problems when displaying, querying, and identifying features.
Cause
In the sde.st_domain_methods package, the ODCIIndexStart function has a variable string defined as 32 characters, that is not long enough to support schemas names which exceed 24 characters and the name of the spatial index.
Workaround
Use a schema name with fewer characters or query the data without a spatial index (which encounters performance issues with large tables because each spatial query results in a full table scan).
    Article ID:000010911
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
