BUG
Encountering an underlying DBMS error when using the sdeexport command with the -O option and st_geometry tables
When using the 'sdeexport' command with the -O option when the layer is using st_geometry in Oracle, the following underlying DBMS error is encountered:
Code:
sdeexport -o create -l cntry,shape -O -f cntry_exp -u gdb -p gdb -s laurel -i esri_gdbArcSDE 9.3 for Oracle10g Build 440 Sun Jan 6 12:00:15 2008
SDEX File Export Administration Utility
Exporting ArcSDE object to "cntry_exp" in SDEX export format ...
Exporting table "cntry".
Spatial column "SHAPE"
SDE Code (-51)= Underlying DBMS error
Extended DBMS error code: 904
ORA-00904: "S_"."GY": invalid identifier
SELECT CNTRY.SHAPE.area, NAME, ABBREVNAME, FIPS_CODE, WB_CNTRY, 1 SHAPE, OBJECTID, CNTRY.SHAPE.points,CNTRY.SHAPE.numpts,CNTRY.SHAPE.entity,CNTRY.SHAPE.minx,CNTRY.SHAPE.miny,CNTRY.SHAPE.maxx,CNTRY.SHAPE.maxy,CNTRY.rowid
FROM GDB.CNTRY CNTRY WHERE ST_EnvIntersects(CNTRY.SHAPE,:1,:2,:3,:4) = 1 AND s_.rn =1
order by s_.gx, s_.gy
Error in stream fetch.
SDE Code (-1): Operation Failed
Error in exporting SDE feature/attribute data.Error exporting SDE export file.
sdeexport error.
1 features converted.
0 features exported.
Cause
There is an invalid binding specification within the 'sdeexport' command; therefore the SQL statement cannot fetch the data in the order of the spatial index, which results in the underlying DBMS error.
Workaround
To avoid the error and work around the problem, do not specify the -O option when executing the command. The features will be successfully exported, but will not be exported in the order of the spatial index.
    Article ID:000010185
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
