BUG
Embedded FMW workspaces in a Spatial ETL tool are not editable
Last Published: December 1, 2022
When using a Spatial ETL tool with an embedded workspace and editing the embedded FMW workspace, the Workbench app launches but the workspace canvas is empty and a Workbench dialog returns a 'file not found' message similar to the following and shown in the image below.
Warning:
File 'C\Users\<username>\AppData\Local\Temp\1\ArcGISProTemp45416\sz1k.fmw' does not exist.
Would you like to remove it from recent files?
Clicking Yes in this dialog only removes the item on the Recent List of the Workbench app. The FMW file cannot be edited at this point and requires a patch to be editable.
Cause
The embedded FMW file is a BLOB field stored with the tool and when tool launches the Workbench app, the creation of the tmp workbench file fails, thus an empty workspace canvas is opened. The embedded workspace itself is still with the ETL tool, you can still open the tool in the Geoprocessing pane and run the tool. You just can’t edit it.
Workaround
  • To edit an embedded FMW workspace in ArcGIS Pro 3.0, open a map and create the Spatial ETL tool with an embedded FMW file.
  • To edit an embedded FMW workspace in ArcGIS Pro 3.1, embed the FMW file on the Spatial ETL tool in the context of a map window.
In an instance where the Spatial ETL tool with an embedded FMW file is non-editable, open the .atbx file with 7-Zip to retrieve the embedded FMW file.
Article ID: 000028068
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Data Interoperabilityx
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
