BUG
Double-clicking the map document in Windows Explorer does not open it in a new ArcMap session
Double-clicking the map document in Windows Explorer does not open it in a new ArcMap session.
Cause
This is a known issue.
Workaround
  1. Start Windows Explorer, browse to C:\Program Files\Common Files\ArcGIS\bin\ and double-click on ArcGISFileHandler.exe to start it.
  2. On the Map Options tab, select 'Open in running application'.
  3. Click OK to close the ArcGIS File Handler application.
  4. Start C:\Program Files\Common Files\ArcGIS\bin\ArcGISFileHandler.exe again.
  5. On the Map Options tab, select 'Open in new application'.
  6. Click OK to close the ArcGIS File Handler application.
Article ID:000011103
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
