BUG
Map documents saved with the Page Setup option 'Same as Printer' enabled may experience problems when opening these documents in ArcMap 9.0. These problems may include: - The page setting switching from the printer the map document is saved with to the default printer on the user's workstation.- Scaling the entire map to the default printer's default page size if the 'Scale map elements...' was turned on when the map document was saved.
ArcMap 9.0 does not properly sense the version of the software the map document was saved in. ArcMap 9.0 has several improvements related to the handling of opening map documents with 'Same as Printer', or 'Use Printer Paper Settings' as it is referred to in 9.0. The software needs to properly switch between reading 8.x saved map documents and reading 9.0 saved map documents.
Article ID:000006914
Get help from ArcGIS experts
Download the Esri Support App
