BUG
Direct Connect does not work unless server name is included
When using Direct Connect in SDEWORKSPACE, the following errors may result during service administration and the service does not start:"<WARNINGS><WARNING code="192" message="
[ERR0927] ImageServer on MYMACHINE: Layer with ID 0 cannot be created. Unable to establish connection with datasource."/></WARNINGS>> Jan 7, 2005 12:58:40 PM: java.lang.String
<?xml version="1.0"?>
<ERRORS>
<ERROR message="[ERR0125] Error when trying to administer Service."/>
<ERROR message="[ERR0930] Check your map file's layers and data source connections. ArcIMS service dc cannot be created." />
</ERRORS>"
Cause
One possible cause for this set of errors is that a server name is not included in SDEWORKSPACE.
Workaround
ArcIMS is expecting a string value for the SDEWORKSPACE server attribute. Any non-space value can be assigned to this attribute. In the following example, server has been set to 'myserver'.
<SDEWORKSPACE name="sde_ws-0" server="myserver" instance="sde:sqlserver:myserver" database="mydatabase" user="map" encrypted="false" password="mypassword" />
    Article ID:000007603
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
