BUG
Define overviews tool sometimes creates invalid cell size ranges
After adding rasters to a mosaic dataset, running the 'Define Overviews' tool sometimes ends up with invalid cell size ranges (MinPS>MaxPS) on the newly created overview items. This issue is data specific.
Cause
The 'Define overviews' tool only computes visibility of newly added overview items -- leaving primary rasters untouched, in some cases (data specific), cell size ranges are incorrectly calculated.
Workaround
The issue can be avoided by one of the following workflows:
  • Run 'Add Rasters To Mosaic Dataset' with 'Update Overviews' option on,
    or run the 'Build Overviews' tool directly after adding rasters to mosaic dataset. This is the standard workflow.
  • If the advanced 'Define Overviews' tool needs to be run and invalid cell size ranges are experienced, the 'Calculate Cell Size Ranges' may be run after 'Define Overviews' to correct them. After this, it is possible to proceed to build overviews.
Article ID:000010927
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
