BUG
Data disappears from the map view when tables are joined to shapefiles
** This issue is addressed in ArcGIS 9.0 Service Pack 3 (SP3) **
If a table was joined to a shapefile using the 'Keep only matching records' option, and a definition query was created using fields from both the table and the shapefile, then the data disappeared from the map view.
Cause
This is a known issue.
Workaround
** This issue has been addressed in ArcGIS 9.0 Service Pack 3 (SP3)
Click on the link in Related Information below for Service Pack 3, if necessary. **
    Article ID:000007781
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
