BUG
Data and/or data frame shifts when printed or exported from ArcMap
The data or data frame in a map shifts when printed or exported from ArcMap.
Cause
This is a known issue.
Workaround
  1. Right-click on the affected Data Frame and select 'Properties'.
  2. Select the Size and Position tab.
  3. Change the state of the 'As Percentage' check box. Click OK and return to the map.
Article ID:000008007
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
