BUG
Copy/paste of a geometric network from an enterprise geodatabase fails
Following an upgrade to a version 10 or later release, copying and pasting a geometric network from an enterprise geodatabase fails if the geometric network was versioned prior to the upgrade.
Cause
The geodatabase upgrade associates unnecessary metadata to some network system tables. The copy/paste operation attempts to copy this metadata, which causes an "Item not found" error when pasting.
Workaround
There is an SQL Script which can be run against the database through the DBMS client (SQL Management Studio for SQL Server or SQLPlus for Oracle) to clear the metadata from the network system tables. These scripts are only available through Esri Support Services. Please contact Support to confirm this issue.
    Article ID:000011329
    Software:
    • ArcMap
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
