BUG
Connectivity rules cannot be added or removed from a geometric network
When using ArcGIS 10.x, connectivity rules cannot be added or removed from a geometric network. This issue is exposed through adding connectivity rules through the geometric network property page or through adding connectivity rules through the geoprocessing tools.
Cause
This issue is due to NIM079465.
Workaround
The only workaround for this issue is to use ArcGIS 10.1 SP1 to add/remove connectivity rules, as it contains the fix for NIM079465.
    Article ID:000011728
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
