BUG
Connecting to the License Server by way of Remote Desktop causes hardware key problems
Using Remote Desktop to access the ArcGIS 9.2 License Server (the machine running the ArcGIS License Manager), results in failure to detect the USB hardware key. The following error is returned:"The SuperPro driver appears to be installed and running. However, the hardware key does not appear to be plugged into a parallel port on this system."
Cause
This is a known issue with ArcGIS License Manager version 9.2.
The use of Windows Remote Desktop to connect to a License Server results in the Sentinel driver being unable to detect the hardware key, which causes the License Manager Service to stop.
Workaround
  • Disconnect from Remote Desktop and restart the ArcGIS License Manager locally on the server.
  • Uninstall the 9.2 ArcGIS License Manager and the Sentinel Protection Installer with add/remove programs, and install the ArcGIS 9.3 License Manager linked below in Related Information. The 9.3 version uses a different sentinel driver and is not effected by Remote Desktop in the same way.
Article ID:000009178
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
