BUG
Columns from a joined table are not visible in ArcMap
** This issue has been addressed in ArcGIS 9.1 **
This condition results from the following procedure:1. Load into ArcMap a feature class or shapefile, and a table that can be joined to it.2. Join the table to the feature class.3. Click on Selection > Select by attributes. At this point the columns from both tables are visable in the Fields list.4. Remove the feature class and table from ArcMap. Do not remove the join before performing this.5. Add them in once more and repeat Steps 2 and 3. Now only the columns from the feature class are visible in the Fields list.
Cause
This is a known issue.
Workaround
** This issue has been addressed in ArcGIS 9.1. **
This condition persists for that particular set of data until restarting ArcMap, reopening the project, or starting a new map document.
Article ID:000007025
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
