BUG
Classified renderer allows the break values to be adjusted higher than the maximum value of the raster but not lower than the minimum value
When attempting to change the break values to apply to a greater range of values, the maximum value can be adjusted to a value larger than that contained in the raster; however, the minimum value can not be changed to a value lower than that contained in the raster.
Cause
This is a known issue with the Classified renderer.
Workaround
  1. Create a raster that contains the range of values needed.
  2. Save it as a layer file.
  3. Use the layer file to import the symbology to the desired raster.
Article ID:000010983
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
