BUG
Cannot use datasets from Oracle 11g or Oracle 12c R1 with multiple geometry fields in Insights for ArcGIS
Adding a dataset from an Oracle 11g or Oracle 12cR1 database will fail in Insights for ArcGIS if the dataset has multiple geometry fields and has multiple entries in USER_SDO_GEOM_METADATA view.
Cause
This failure is caused by an issue in Oracle 11g or Oracle 12c R1 databases.
Workaround
Upgrade your Oracle database to a newer version.  For more information on which Oracle versions can be used with Insights, see Supported databases.
Article ID:000020718
Software:
  • ArcGIS Insights
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
