BUG
Broken data source link when opening a 10.0 MXD map that has a query layer saved in 10.1 beta 2
A broken data source link may be encountered when opening a 10.0 MXD map that has a query layer saved in 10.1 beta 2.
Cause
ArcMap 10.1 beta 2 saves the query layer data source/connection information incorrectly.
Here is the workflow to reproduce the problem:
1. Create a feature class in an ArcSDE 9.3/Oracle 11g R2 database using SDO_Geometry keyword.
2. Open ArcMap 10.1 beta 2, add the SDO layer as a query layer.
3. Save the MXD as a copy, using the 10.0 MXD document format.
4. Open the MXD from any ArcMap 10 client that uses the same Oracle client (11g R2). The query layer shows a broken data source link. Double-check the layer properties, and an invalid feature class name can be seen in the data source, similar to the following example:
Data Type: Query Feature Class
Feature Class: TEST.%SDE_931
DBCLIENT: oracle11g
SERVERINSTANCE: sde:oracle11g:orcl
AUTHENTICATION_MODE: DBMS
USER: test
PASSWORD:
Workaround
This is a bug in 10.1 beta 2, no workaround is available at this time.
    Article ID:000011461
    Software:
    • ArcMap
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
