BUG
ArcIMS Z39.50 connector disables ArcIMS Java applications: Author, Administrator, Designer
While running the ArcIMS Z39.50 Connector, the ArcIMS Author, Designer, Manager and Administrator applications may fail to run properly or not start.
Cause
The logging window that appears when the ArcIMS Z39.50 Connector is started is using system resources in a way that causes other Java applications to fail.
Workaround
Disable the Java logging window in the log.properties file.
  1. Open the log.properties file in a text editor; for example, NotePad. Locate the file at: <ArcIMS Installation Folder>\Metadata\Z3950Connector
  2. Delete the reference to the JavaWindow logging appender by deleting "JavaWindow" from the second line of the file.
    Before modification:
    Code:
    # declare your logging appenders here
    log4j.rootLogger=DEBUG, stdout, JavaWindow, Access, Debug
    After modification:
    Code:
    log4j.rootLogger=DEBUG, stdout, Access, Debug
  3. Save and close the file.
  4. Stop and restart the ArcIMS Z3950 9.0 service.
    - When using Windows NT, select Start > Settings > Control Panel > Services
    - When using Windows 2000/XP/2003, select Start > Settings > Control Panel > Administrative Tools > Services
Article ID:000007048
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
