BUG
An error occurs when adding SDC 1 format datasets to ArcMap
After adding two or three SDC1 datasets, the following error message is displayed:"ArcMap has encountered a problem and needs to close."SDC1 datasets are found on the ESRI Data & Maps discs from 2003 or 2004.
Newer ESRI Data & Maps discs have a newer revision of the data that does not cause the problem.
Cause
Earlier versions of SDC, found in older ESRI Data & Maps media kits, are incompatible with newer versions of ArcGIS.
Workaround
Use SDC 2 format datasets. SDC 2 datasets are found in the 2005 or more recent ESRI Data & Maps data.
Article ID:000009175
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
