BUG
Aggregating in ESRI network feature fails using COM_INTERFACE_ENTRY_AUTOAGGREGATE_BLIND
When using Active Template Library (ATL) to create a custom feature, accessing the feature fails if the ATL COM_MAP is specified using COM_INTERFACE_ENTRY_AUTOAGGREGATE_BLIND.
Cause
The ATL macro is prematurely releasing the last reference to the inner aggregated network feature in its constructor. This is due to the current implementation of NetworkFeature.
Workaround
  1. Use COM_INTERFACE_ENTRY_AGGREGATE_BLIND in the COM_MAP.
  2. Aggregate the ESRI network feature in the FinalConstruct method.
Article ID:000003063
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
