BUG
Address locator failed to create with the error message: Unable to store the address locator. Locator cannot be validated[Unhandled application error]
This issue is addressed with ArcGIS 9.3 Service Pack 1 (SP1)
The following error occurred when creating a new address locator in an ArcSDE 9.3 geodatabase:
"Unable to store the address locator. Locator cannot be validated[Unhandled application error]".
Cause
This is a bug for ArcSDE 9.3: Creating address locators fails in ArcSDE if numeric fields in the SDE reference feature class contain null values.
The issue has been corrected in ArcSDE 9.3 Service Pack 1. See the Related Information section below for ArcSDE 9.3 Service Pack 1.
Workaround
  • Apply the ArcSDE 9.3 Service Pack 1.
  • If it is not possible to install ArcSDE 9.3 at this moment, one of the following methods can be used to work around this issue:
    1. Convert the numeric fields into text fields, and use the text fields to build the address locator.
    2. Create the locator in a file or personal geodatabase, and copy the locator to the ArcSDE database.
Article ID:000010409
Software:
  • Legacy Products
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
