BUG
Add Rasters to Mosaic Dataset tool returns an error or crashes when the tool is running in the background
The Add Rasters to Mosaic Dataset tool crashes or returns an error.
Cause
This issue is known to happen in the following cases:
• The Raster Type Properties have been edited.
• Background processing is enabled.
• The results of the geoprocessing operations are set to be added to the display.
• The operating system is either Windows 7 or Windows Vista.
Workaround
There are two potential workarounds for this issue:
• Turn off background processing.
• Turn off the option to add geoprocessing results to the display.
    Article ID: 000011201
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
