BUG
A GlobeXplorer map isn't in the correct projection
The returned GlobeXplorer map isn't in the requested projection.
Cause
GlobeXplorer doesn't support projection strings.
Workaround
If using a standard projection string, switch to using its corresponding ID. For a list of projection strings and IDs, see ArcWeb Online link below.
Choose a different projection if the original string doesn't have an associated ID.
Article ID:000007685
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
