BUG
A custom geographic transformation in ArcMap is incorrect
After defining a custom geographic (datum) transformation, the results are incorrect or a dataset doesn't line up properly with other data.
Cause
The Y translation (dy) transformation parameter is always set to zero by the transformation process. This parameter can be viewed in the status text at the bottom of the dialog.
Workaround
This is addressed in ArcGIS Service Pack 2.
    Article ID:000007388
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
