BUG
BUG-000162145 Split, Divide, and Clip give unexpected results or fail when the target layer is projected on the fly
Last Published: October 18, 2023
ArcGIS Pro 3.1 and 3.2 contain a bug that causes unexpected results when using Editing tools that split features when the target layer is being projected on the fly. Affected tools: Split, Divide, and Clip. The following behaviors may be observed when encountering this bug:
  • When using Split to interactively split multiple selected features, some of the target features may not be split after the operation is completed.
  • When using Split By Feature, it may fail to split target lines.
  • When using Clip, target features may be offset from the source features that were used as input after the operation is completed.
  • When using Divide, the operation may fail with a Divide Features failed error.
Workaround
Ensure the target features are not being projected on the fly so that the coordinate system of the target layer matches the map's coordinate system.
Article ID: 000031417
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
